Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prepping
Thread: Prepping
Old 05-10-2004, 02:20 PM
SJU SJU is offline
I have stripped the car to bare metal. I was told to put an etching primer on the bare metal then do body filling etc. then prime with a different primer.
I have since been told that I cant put filler over the etching primer because the acid neutralizes the hardener in the filler. So now I have part of the car with etching primer and part of the car with bare metal and no body work done. I was told to put epoxy primer over the etching primer and then the fill work then more epoxy primer. But what about the part that is still bare metal. can I go straight to an epoxy primer, or start with an etching primer on that as well. Help, I am a first timer and I'm determined to do this. Is there a good web site with step by step instructions?
Totally confused.
