If your using enamel just let it be. The epoxy over it will make it a lot stronger. Its the urethanes that cause the melting problems.
If you were to take it off 80grit on da will remove acid etch in no time.
you can put the glaz or bodyfiller over bare metal or epoxy, your choice
