Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prepping
Thread: Prepping
Old 05-11-2004, 09:12 AM
Centerline Centerline is offline
Wiki Edits: 49
Originally posted by BarryK
you can put the glaz or bodyfiller over bare metal or epoxy, your choice
I disagree. Using body filler over bare metal promotes rust. The filler is porous and it can and will trap moisture under the filler which will allow the surface to rust over time. This is the exact reason for using either a self etching primer or epoxy primer over the bare surface prior to doing bodywork.
Centerline
