Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prepping
Thread: Prepping
Old 05-11-2004, 04:58 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally posted by BarryK
But you need to educate yourself on the acid etch primer as far as putting body fuller over it. Do it yourself but don't give that advice to other people as that is a major problem waiting to happen both short term and long term.
I still disagree. When I worked in the industry we did it every day and I've never had a problem with filler over self etching primer. I will admit that there could be a problem if the primer isn't fully cured which can happen if the tech is in too much of a hurry but in 99% of the cases it works just fine.
