Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prepping aftermarket panels for paint?
Old 02-08-2013, 02:18 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
Originally Posted by Alpha67 View Post
Thanks guys - I knew the sanding of the exterior surface was a must - was wondering if I could avoid sanding the nooks and cranny's of the inside of the fender though (will be visible/exposed on the engine compartment side
Unfortunately with body prep there is no easy way out, that's why not everyone enjoys it. You do have to scotch brite all the surfaces in order for whatever you put on top of it to stock to it.
I would use maroon scotch brite (320 grit) pad and then give it 1-2 coats of epoxy (I use SPI) and wet sand that with 400-600 and you're ready for paint.
Here's some pics of fenders I did for a guy with the above process.
ID:	71185   Click image for larger version
ID:	71186   Click image for larger version
ID:	71187   Click image for larger version
ID:	71188   Click image for larger version
