Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prepping aftermarket panels for paint?
Old 02-09-2013, 10:58 AM
Alpha67 Alpha67 is offline
Originally Posted by 33Willys77 View Post
You can do this easy by sanding it with 180, prime (probably etch prime) and seal if necessary and apply paint. Wet on Wet, no sanding in between. This is done all the time in repair shops on a daily basis.
Thanks - Wet on Wet; Does this mean I can spray a sealer and immediately after spray the paint? By sealer, is this just primer, or something special?
