Prepping Front Spoiler For Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2009, 03:08 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I am going to repaint the front spoiler from my T-type. I have removed it from the car wet sanded with 240g w/d and I am not sure of the next step.
The OE paint (bc/cc) was shot apparently right over the plastic, I don't see any signs of primer. It is a yellow colored plastic, not sure of the type.
Do I wet sand with a finer paper and paint (black) right over it, should I prime it first before paint?
If primed first I already have a PPG 2k primer surfacer with hardener will it work, is there some other primer to use first, if needed?
Thanks
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
critique this tubular front chassis setup lowROLLERchevy Suspension - Brakes - Steering 9 07-05-2008 05:32 AM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
Idler Arm help after front tire change 360Camaro Suspension - Brakes - Steering 1 12-28-2003 11:49 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
