Prepping gel coat for primer - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-31-2013, 06:14 PM
Originally Posted by Ryokoe2925 View Post
That's what I was thinking. I am about to repaint my whole truck but above my wheel wells was all rust so I cut out most of the rust. I'm just gonna throw some fender flares over the cutout metal. If I self-etch the metal should the rust stop?
No... no epoxy will stop rust. Spray it with rustmort or similar product. let it dry thoroughly. You can then spray over that if you choose to do so.
I've sold HUNDREDS of gallons of this 2k and it is really good. I use it as well but I've heard good stuff about SPI as well.
Transtar 6131 2K Epoxy Primer Sealer Gray
aviation primer / base coat compared to auto primer / base coat dogwater Body - Exterior 8 04-21-2013 10:58 AM
Anyone use Redi-Coat in Michigan to dip strip and e-coat primer your body shell? Chuck78 Body - Exterior 5 09-03-2011 06:08 PM
Gel -Coat repair DV8 Body - Exterior 8 04-20-2007 09:15 PM
66 Vette Gel coat or not? badazz55 Body - Exterior 43 04-10-2006 09:04 AM
laminating- gel coat pre-release powderbill Body - Exterior 5 06-12-2005 05:59 PM
