prepping motor for install - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2007, 04:41 PM
dawg's Avatar
NAVY VETERAN
I found high temp rtv between the intake and heads.
im sure there wont be any vacum leaks but im concerned about performance?
I dont feel like taking the intake off to correct that issue but will try to scrape or cut most of it off.
engine runs on dyno fine but im sure i can get better flow without the RTV in the way.
whats the best approach for the removal of the RTV without disturbing the intake?
pics are of each side.
same amount just about everywhere.
see pics:
Old 08-22-2007, 04:45 PM
Leave it alone, it won't do squat to remove it. There isn't any good way to get it out other than what you can pick off via the plenum opening.
Old 08-22-2007, 06:02 PM
opinionated old fart
Last journal entry: Sheetmetal
big question would be, why is it there?
Larry
Old 08-22-2007, 06:48 PM
It is not uncommon for some builders to skim the intake ports with a coating of RTV when they do the water jackets and front and rear mating surface.
We don't, but we do apply, to the head side, a light coat of weatherstrip adhesive and stick it on the head about 15 minutes before mounting the intake. That way the stay in place when mounting the intake.
Old 08-22-2007, 07:12 PM
GMC boogie's Avatar
Not flaming ya but,that 3M weatherstrip adhesive works a little to good. Its a PITA during disassembly and clean up.
I am sure a "light coat" would be much easier than some of the work I have come behind.
Old 08-22-2007, 07:17 PM
A few dabs will do it.
Old 08-22-2007, 08:02 PM
I never use weatherstrip adhesive PITA 4 sure to get off..... i also never use silicone around the intake ports or around the water jackets.....Only place i use it for intake is at the ends where the rubber ends would normally go and i run it up about 3/8" up on the head from the block..There are other ways to hold the intake gaskets in place besides glue
Prepping urethane bumpers and fiberglass parts? starquest Body - Exterior 19 12-21-2007 09:54 AM
Paint Prepping what grit paper for primer stages? camaro freak Body - Exterior 4 04-29-2007 09:06 AM
prepping and starting a new 350 crate motor 65truck Engine 2 09-29-2003 12:29 PM
Prepping Aluminum Interior for Paint/Clear maxx levell General Rodding Tech 3 08-31-2003 03:53 PM
Prepping fiberglass hood 80Camino Body - Exterior 3 11-02-2002 04:21 PM
