Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - prepping for Por 15 without the marine clean step
Old 12-26-2012, 10:19 PM
mr4speed mr4speed is offline
Tech 69, speaking from personal experience with por 15 don't think there is any way to stop it from peeling off in sheets. Have used it over rust, prepped it properly over clean steel and still if you have to drill a hole or grind a small area to do a repair it seems it will always peel off in big areas. It just will not feather out like paint does. Just giving you my experience with the stuff, mabey someone else will have a better solution.
