Prepping Rusted Replacement Panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 04:42 PM
Ive seen some cheap replacement panels on eBay
Theyre New Old Stock, so they've never been fitted, but have surface rust on them
If I bought them how should I prep them?
Should they be epoxy'd before welding, or is it not possible to weld through epoxy?
Old 02-07-2011, 09:18 AM
302 Z28's Avatar
Surface rust is not a problem, sand it off and get with it.
Vince
Old 02-07-2011, 09:26 AM
jeffery wells's Avatar
don't weld threw epoxy, BIG MESS and a welder needs a clean surface for it to stick, just sand off the rust, clean the surface, and prime. pretty simple.
Old 02-07-2011, 05:43 PM
Thanks guys
Old 02-07-2011, 11:58 PM
you can use rust remover i use tnt gel and scuff pads works well i think there website is tntrustremover.com I bought a gallon and did entire car that i stripped and left it to get rusty
Old 02-08-2011, 08:09 AM
302 Z28's Avatar
If all you have is a light surface rust I would not use any rust remover products. If they are not removed or neutralized totally you can risk adhesion problems developing with your finish.
Vince
Old 02-08-2011, 08:19 AM
I plan to remove all rust prior to fitting
But, it may be a while before the car gets painted so I was just wondering what the best approach would have been
Old 02-08-2011, 09:42 AM
i know this sounds crappy, but if it's going to be sitting a while longer, sand it down, and wall-mart primer. you can sand the primer before laying down a good primer for paint, dont paint over wall-mart primer, it will simply preserve it so it dont get worse.
Old 02-08-2011, 04:10 PM
boatbob2
rusty panels......
Hi,fit the panels first,then sand the rust off the panels, then prime using a good EPOXY primer on both sides of the panel,before you weld,sand the primer off,to clean shiny metal, from the edges of the panels about 1 inch all around.
Old 02-08-2011, 06:59 PM
302 Z28's Avatar
Above advice is "spot on", use a good quality epoxy primer like SPI. DO NOT use any primer from Wal-Mart or any primer in a rattle can for that matter they all will absorb water and eventually rust through. Your best long term protection is with a good quality true epoxy primer.
Vince
where to get cheap replacement panels? Bauer1287 Body - Exterior 14 01-24-2011 06:51 AM
Replacement Panels mechEcwru Body - Exterior 1 11-28-2007 01:58 PM
replacement rocker panels ArmyofOne Body - Exterior 8 01-22-2007 05:57 AM
substructure replacement, rusted cars. p.rebetez Hotrodding Basics 2 07-05-2006 01:27 AM
Rear Qt panels rusted out jdsciencerules Body - Exterior 4 04-12-2006 08:56 PM
