Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - prepping and starting a new 350 crate motor
Old 09-29-2003, 12:29 PM
Lucid Lucid is offline
i would still check around for vacuum leaks, also try spraying a bit of carb cleaner (i use starting fluid, only because I have alot of it) over the carb to see if it idles up, it would explain a lean condition, what's the smoke smell like?
