Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prepping urethane bumpers and fiberglass parts?
Old 01-31-2006, 07:42 AM
BondoKing's Avatar
BondoKing BondoKing is offline
KING OF BONDO
Last journal entry: My little helper
Stay away from the aircraft stripper and just use 80 grit... put 2 good coats of epoxy, let set over night, then 2k next day and block...
BTW on your metal, I hope you cleaned the metal really good before you started running the DA with the chemical stripper.. If not chances of you having problems are almost gaurenteed... You need to remove such things before sanding and grinding it in the metal or plastic parts for those who use it...
I used it years ago, but I no longer do, too many issues can come from it vs just sanding it down
