-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   pres n snap tool? (http://www.hotrodders.com/forum/pres-n-snap-tool-232195.html)
JCAR 04-24-2013 08:44 PM
pres n snap tool?
I want/need to buy a pres n snap tool. Hoover seems to be the standard, but when I look at all of the different fasteners and die options, my head starts to spin. Cost is not really a concern, I want a quality tool that I should only have to purchase once. Any advice on tool brands and "standard" dies and fasteners is appreciated. I know the tool will see limited use...but when you need one, you need it. Thanks, Jeremy.
DanTwoLakes 04-24-2013 09:07 PM
You really need only the Press N Snap tool and the button and socket dies that come in the kit. Perfectfit has the tool and 4 piece die set for $112, and that's about as cheap as you'll find. http://www.perfectfit.com/15336/1544...Snap-Tool.html There are dies for Durable Baby Dot fasteners, but unless you use a lot of snap fasteners they are not necessary. Then you will need caps, sockets, studs, and eyelets. Make sure you get both nickel over brass and stainless versions. You can add other things later.
DanTwoLakes 04-25-2013 09:05 AM
1 Attachment(s)
BTW, they also make a fixture to bench mount the Press N Snap.
waybomb 04-28-2013 01:15 PM
Timely post! I am tired of my pos $29 stamped steel snap tool.
I just ordered one from perfectfit along with some snaps. Nice price.
Thanks for the lead!
JCAR 05-01-2013 02:54 AM
Thanks Dan, that's the same tool I was eyeing. I have bought a lot of stuff from perfect fit, they always seem fair priced and shipping is timely. Thanks again, Jeremy
waybomb 05-14-2013 07:00 PM
Rcvd my press-n-snap tool. Also bought an Osborne 155 0-6 hole punch.
I've owned boats for 26 years now and have probably replaced 200 snaps with the wpos cheapo snap tools. I could kick meeself in the arse.
I should have bought the Press-n-Snap tool and the Osborne hole punch 26 years ago. These tools are a dream. I used to dread replacing snaps, because it was hard to do with the stamped steel tools and usually ended up doing each snap multiple times.
If you do snaps, you need these two tools!
