We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 03-04-2006, 12:53 PM
msc66's Avatar
msc66 msc66 is offline
preserving vinyl dash
My dash pad is in good shape and I'd like to keep it that way. What is the best conditioner to use on vinyl dashes?
Old 03-06-2006, 01:35 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Rob Keller's barnstar
Wiki editor
Last wiki edit: How to clean glass
Wiki Edits: 38
I use black magic make sure you keep it clean & try to keep it out of direct sunlight. make sure whatever you use it has U V protection
If you really want to keep it nice get one of them custom dash rugs to lay over it for daily use
DO NOT use armor all that **** sucks!
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 03-06-2006, 02:36 PM
FASTCHEVY's Avatar
FASTCHEVY FASTCHEVY is offline
RatRod B4 RatRods were Cool
Someone told me Armor All made the dash crack faster, I argued with him but
he swore up and down that it did.
I would like to know the real deal on this too.
Old 03-06-2006, 03:39 PM
Rob Keller's Avatar
Wiki editor
Wiki Edits: 38
I dont like A A because it builds up fast & attracts dirt .
Have you ever grabbed a sticky gooey steering wheel in the middle of summer?
if you have that is most likely A A .
YUK & GAK!
The key to it is to keep it supple so that it will flex when needed to.
Here the temps are extreme & do some serious changes some times from 30*F to 70-80*F in a few hours but even up north when its cold & the heater /defroster will put it through the paces.
I use a good Leather & plastic cleaner to clean all my interior stuffs
here's what I use to clean .
Malco L&P Cleaner
I would also think their conditioner would be good too I've been using this product for over 20 years make sure you dilute it down @ least 20:1 for interior stuff
Malco conditioner
R
"SlowRide66"
Old 03-06-2006, 03:48 PM
1ownerT's Avatar
1ownerT 1ownerT is offline
1ownerT's barnstar
Wiki editor
Last wiki edit: Building a new shop
Wiki Edits: 2
In my experience, they are right. My wife had a 75 Monte when we met, dash and vinyl roof in excellent condition, within 1 year of using Armor All both were severely cracked along with the side walls on her tires.
That was the only proof I needed, and have never used the stuff again.
Old 03-06-2006, 05:42 PM
Longboard's Avatar
Longboard Longboard is offline
I was at a hot rod shop the other day and they used some type of marine prduct. Not sure but it was #203? I think. I'm following up to find out for sure, but has anyone else used a marine product?
Old 03-14-2006, 02:45 AM
tinman386 tinman386 is offline
tranny fluid
This guy might have been goofy. I knew a guy that used tranny fluid on his dash and said it works great. I know a little bit about plastics and what the sun and the uv rays do is remove the plastisizers in the plastic. this is what keeps them pliable to prevent cracking. So im pretty sure tranny fluid or anything that could either keep in or add to as a plastisizer would do the trick.
Old 03-15-2006, 09:57 AM
shearcyr shearcyr is offline
Those who wander are not lost
I usually use stoner vinyl contidioner, boat conditioner is generally about the same. the way I see it, vinyl conditioner is alot like skin conditioner, if you always use it frequently, and then completely stop using it your skin would be dry bc it has built sort of a dependency. from what I have seen having lived in maine my whole life, the best thing you con do is either never use it, and do what you can about staying out of the sun, or use it frequently and keep it well conditioned. I have never heard the tranny fluid gig.... sounds pretty funny however I have heard and have tried using sun tan lotion.....beleive it or not, it looks good however, it is a little greasy when it gets hot, so don't use it on the steering wheel you'll be sorry.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "preserving vinyl dash"
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 16 07-23-2007 06:35 PM
justdashes/trashes my dash cozmo Interior 8 08-02-2006 12:25 PM
My work in progress custom dash: advice needed. friday Interior 4 06-23-2006 07:02 PM
fiberglassing a vinyl dash jacobm99 Interior 18 05-06-2005 01:32 PM
covering dash with vinyl? texasfinest1 Interior 3 08-07-2004 12:27 PM
