press the brake pedal and the engine sputters.??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2006, 09:22 PM
i have a chevy stock 250 l6. when the engine idles sounds like #5cylinder is missing. i know i have to replace the camshaft before i blow a hole in the piston. the exaust lobe is worn down a bit. so here`s the deal . other than all these other problems. sould that be why the engine sounds like it misses and when i press on the brake pedal. the engine revs up about 600 rpm.
maybe i have the vaccum advance hooked up wrong.
if someone could help me i`d apreciate it. kinda my work truck and everyday driver. kinda gets annoying having the motor rev up while i`m stopped and it misses real bad.
Old 07-22-2006, 07:23 AM
Have you tried removing the power brake vacuum line and pluging it? It sounds like the PB booster is leaking.
