Press brake question: 1/4" plate on a 1" die
Part is 1/4" steel, 1.2" wide by 12" long and needs a 4 degree bend down the middle.
Due to the narrowness of the part that pretty much limits me to a 1" V die on the bottom. Any idea what sort of tonnage Im looking at on this ? I used to know the answer but just cant recall any more. I know a full bend at these specs would be about 60T, but that also doesn't really apply to the first few degrees either. All i remember from last time i did something like this is that the die was rated at 60T / foot and i didnt blow it up, but then again my boss put a full 350t to a 4 foot length of .125 in the same dies and that didn't blow the bottom die either. |
Tonnage chart
http://www.freetechnicalcharts.com/P...nage_Chart.php Bend calculator http://www.pacific-press.com/bend-fo...lculator-b.php Last edited by Pantaz; 06-07-2011 at 08:49 PM. Reason: Add'l reference |
charts and calculators are for 90* bends, I need to know the tonnage required for 4 degrees, theres a very big difference.
4 degrees requires almost the same tonnage as 90 degrees
The tonnage to bend metal to its yield point over a v-die is probably 80% of the tonnage required for 90 degrees. For a better description see page 7 of the Cincinnati Press Brake Capacity Guide: http://www.e-ci.com/pdf/Press-Brake-...es_PT50691.pdf
A 1" die is smaller than usually recommended to bend 1/4". Normal is 8 times material thickness or 2" but small angles can certainly be bent over a smaller die if you have the tonnage. |
| Recent Garage - Tools posts with photos |
| ccimotorsports Press Release "Baddest Buick In The Land" | Only Racing | Hotrodders' Lounge | 8 | 06-22-2009 10:48 PM |
| "electric vacuum pump for the brake booster" | Joe DA | Suspension - Brakes - Steering | 19 | 01-28-2009 09:13 AM |
| 39 chevy license plate "French" job | les88404 | Body - Exterior | 3 | 01-29-2008 11:32 AM |
| A very handy tool,sort of a "hand brake". | MARTINSR | Body - Exterior | 8 | 03-29-2006 04:23 PM |
| Hey croz look """"IMPORTS SUCK""" | 78 monte | Hotrodders' Lounge | 14 | 08-30-2002 01:13 PM |
