Pressed or bushed piston pins - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2002, 09:30 PM
Post Pressed or bushed piston pins
Whats the difference between Pressed or bushed piston pins? Thanks, Bill
Old 09-12-2002, 03:52 AM
woodz428's Avatar
Troll Hunter
Post
those terms describe how a wrist pin is located in the rod. A pressed pin is held in the rod by an interference fit and is either pressed through with a small hydraulic press or the small end of the rod is heated (with a special element) enough to expand it so the pin will slide in. Bushed rods have a bronze bushing in the rod that allows the pin to move in the rod and piston. The pressed pin is held in place by the interference fit and the free floaters use some kind of retaining clip in the piston to keep it in place.
« 82 351 | Nailhead? »
