Pressed Vs. Bushed Conrod's - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2010, 12:43 AM
Dumb question, what's the difference between the two and why might one be better than the other?
Old 06-12-2010, 01:14 AM
techinspector1's Avatar
Wiki Edits: 326
Costs more money to bush the rods with bronze bushings for floating pins. If it's a race motor that will be torn down periodically, floating pins are easier to disassemble. If it's a street motor that will only come apart when it's worn out, pressed pins will work fine and are cheaper.
Couple of different ways to keep the pin from rubbing the cylinder wall with floating pins. You can use a lock on each end of the pin that fits into a groove that's machined into piston, or you can use a teflon button that fits into the end of the pin on each side and then the soft button rubs on the cylinder wall instead of the hard pin. Some guys worry about the locks failing, so prefer the buttons.
Here's an example of what the buttons look like....
http://www.cbperformance.com/catalog.asp?ProductID=172
Old 06-20-2010, 09:36 PM
How long can the teflon buttons be expected to last?
Old 06-20-2010, 09:43 PM
BOBCRMAN@aol.com's Avatar
Teflon buttons usually last at least the life of the assembly. I know a couple of truck pull/mud guys that re-use them several times..
Questions on floating or pressed fit pistons and rods for SBC 350 eric32 Engine 7 10-30-2015 07:21 AM
Connecting Rods Pressed or Bushed? hotrodtodd50 Engine 9 01-08-2007 02:24 PM
bushed or pressed pin?? 280zxWith305 Hotrodding Basics 2 01-16-2005 06:24 PM
benefits of bushed rods 406chevelle Engine 7 06-20-2003 11:28 PM
Pressed or bushed piston pins bildo95 Engine 1 09-12-2002 03:52 AM
