Pressing in control arm bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 07:01 AM
Does anyone know of a shop that will press in some bushings for me in the Katy area ?
Thanks
Old 02-19-2005, 08:31 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I push them in my self.
I take the metal insert out. Grease the bushing up with vaseline. Press it in with a vice. Then grease up the insert and press it in.
Old 02-19-2005, 10:22 AM
Thanks for the tip
That's a great tip. I made a tool yesterday with a 1/2" dia threaded rod. washers and threaded couplings to squeeze the bushings out/in. That Vasaline will definitely make a difference. I'll give it a try.
Old 02-19-2005, 10:32 AM
bracketeer's Avatar
489 Lemans
Getting bushings out
There was a thread on taking bushings out not long ago. The majority (including myself) burn them out. It's great you made a tool. There is a thread "Whatdidja make?" You may want to post a pic.
Old 02-19-2005, 01:24 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Come-on guys, you know better than that! Tell the missus that you need a Harbor Freight 12 ton floor press to press in some bushings. Then tell her that a shop will charge more to do that simple job than the press costs and you will then always have a press to do more manly jobs so you are saving her money!
Old 02-19-2005, 05:59 PM
success !!!
The vasaline did the trick. All bushings are in and I'm ready to proceed.
Old 03-02-2005, 06:33 PM
79 camaro 454's Avatar
yes
put them in the freezer for a couple of hours then they will just slide in nicely done this on my trans am .
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
Control Arm Bushings 69 chevelle SS Suspension - Brakes - Steering 1 08-10-2003 07:50 PM
78 nova control arm bushings brad_irc Suspension - Brakes - Steering 1 07-20-2003 08:08 PM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 03:19 PM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
