Pressing hoses onto A/C barbed fittings?
Anybody got the secret to getting A/C hoses fully pressed onto barbed fittings (crimp type)? I thought of using a bit of silicon but held off fearing it might contaminate the system. Clues?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Okay, I'm sneaking my wife's hair drying out of the house to see if a little heat will do the trick. Will report back shortly if I'm not caught...and dead.
I do the same as 66chevystepside..
A little refrigerant oil works wonders and helps the seal too. Look in the little hole in the end of the ferrule, you should see the hose. That tells you it is inserted all the way. Heat from a hair dryer won't do much.. Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Hmmmm, refrigerant oil. Not something on my shelf...so it looks like a trip to town.
And NOW...does anyone have the secret to getting the partially installed hose back off so I can get some oil on it? Just to double check here, I assume the hose and ferrule need to be pressed all the way on the fitting to the "collar" noted at the arrow. Correct? And as Mikey says, you need to be able to see the hose in the peep hole? ![]() &%$^#* air conditioning.
You usually get a small clear bottle of refrigerant oil (about 1/4 oz), in your AC kit..it is the same stuff that you lube the fitting O-rings with upon assembly...
I put those fittings in a vise with some wood or teflon vise blocks...then I can lay some lard, (mikey weighs about 265 ),on the hose to work it on.Later, mikey
This is what Vintage Air supplies. When I first mocked mine up, I used some 1/2 heater hose along with some smaller stuff I got from Lowes. The regular heater hose is standard 5/8 - and no big deal. To cut the A/C and heater hose, I used an inexpensive garden pruning cutter. Like Mikey said, you need some beef, but you should only assemble it once as pulling it apart will tend to tear up the inner liner.
Dave W ![]() ![]() I used masking tape and a Sharpie to mark the final fitting placement in the hose - which can just be seen. You can't twist this stuff at all The final run was 'cleaned' up from this photo |
Hey Dave, how much you charging these days for one of your cool custom air cleaners...and can I get same day delivery????
I did get one of those little tubes of oil with my kit...no explanation of what it was so I figured it was some sort of thread sealer. Ooooof. Already ran to town and bought a quart of A/C oil. Looks like I'll have to slice off the hoses I already have partially on...could be a potential problem. I had cut the hoses to optimum length so I wouldn't have any "slack". Now I might be in trouble. Ooooof again. I sure hope any rookies putting together an A/C kit read this thread first. They could learn a LOT from my mistakes. @#$%^& air conditioning.
The 'polished' valve covers are specials as well.A few more pointers - at least for the 'A' builders (or, most likely, any other small body car) 1 - Putting the A/C into a Model A for sure is a challange - particularly if it has an OEM style firewall. A flat Bi@#$in or Direct would make it much easier - my lesson learned - buy a Brookville body and have them omit the firewall. 2 - SBF 5/8' bypass hoses make good right angle turns under the dash for the heater connections 3 - The dryer can be mounted on the car frame instead of the firewall. I had a very nice polished aluminum unit - the inlet and outlet needed to be reversed - the unit I had wouldn't allow that to be done. 4 - If you think you have enough fittings in your "kit" and pointing the right direction. You are probably wrong. I have probably enough extras to almost completely do another car. If any one is interested, I can make you a deal PM me and I'll put a list together and figure out a reasonable well below my cost price (plus shipping).5 - An in-line firewall fitting will work better. My 4 square piece is the biggest reason for so many extra fittings. I think it looks better, but it sure cost a bunch in time and more parts. 6- Don't waste your money on a defrost option if you are using a very small unit. Also, some cars just do not have enough under dash room for 2 more 3" hoses along with the 3 already there for A/C and heat. I didn't but have talked with other that have and found out that they were SOL. There are probably more 'gotchas' but probably wont remember them until the car goes back together Later, Dave W Last edited by Irelands child; 02-06-2008 at 12:33 PM. Reason: Correct oopses |
I finally got everything together this afternoon but what a job. Four hoses, eight fittings, and every one of them was a real PITA. I just don't have Mikey's "girth" to do the persuading for me. But the oil trick did help as well as putting the hoses in a vice so I could put a bit more power to them. Fortunately, even after cutting off the fittings I had already tried to start I still had just enough hose length to make the connections. No slack left now, however.
| Recent General Rodding Tech posts with photos |
| A/C cycles, 3lbs installed | Countilaw | General Rodding Tech | 9 | 03-03-2007 04:08 PM |
| Radiator Hoses for Hot Rod | beam6325 | Engine | 4 | 09-11-2006 06:55 PM |
| A/C hoses -less expensive option for SS covering? | TexasSpeed | General Rodding Tech | 2 | 03-12-2006 10:51 AM |
| A/C Hoses | 30 sportcoupe | Interior | 2 | 06-21-2004 07:36 AM |
| A/C Fittings How to measure? | 76chevyc10 | General Rodding Tech | 2 | 04-24-2004 09:04 AM |
