Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pressing oil pickup tube
Old 12-06-2012, 03:41 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Originally Posted by kentactic View Post
Ive got the 5/8 wrench and im whaling on this sucker. Simply will not even begin to insert. Im pretty sure if i continue this pickup is history. Anything i should try? Give up and have a dude with the fancy tool do it? -Kenny
Begin with OEM parts, not cheezy offshore crap. Make sure there is not a piece of the original tube broken off in the hole and rusted in place. Run a bronze rifle cleaning brush through the hole a few times to remove paint overspray, rust and scale. Remove any paint from the tube, bevel the edge of the tube with a fine-tooth file and store it in the freezer overnight. Next day, apply a very light coating of Vaseline to the tube and tap it in with the proper size box-end wrench and a small hammer. Sit down, open a cool one and admire your work.
And not to be a snot, but whaling is something Captain Ahab did when he was looking for Moby Dick. Beating on a part is called beating on a part, not to be confused with wailing, which is a high-pitched scream.
