Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pressing oil pickup tube
Old 12-06-2012, 04:26 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by kentactic View Post
i will say one thing this pickup is junk. Its rusted on the inside. Id really rather find another one that dosent have rust waiting to fall off and destroy my motor.
Whats the target gap from oil pan measurement im looking for? I think im going to make a parts run to see if OEM will work.
Bad juju Bwana. Rust not allowed. Use modeling clay and mock up the pickup clearance from the bottom of the pan. Shoot for 3/8". Any closer than that could allow the pump to pull the bottom of the pan sheetmetal up against the pickup and shut off the supply to the pump. Don't trust the pickup to just be a tight fit into the pump. Weld it. Once you have the pickup oriented in the proper position, take the pickup and pump to a certified welder and have him weld it for you. Wrap the pump and pickup in wet rags and make sure no welding slag gets into the assembly.
