Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pressing oil pickup tube
Old 12-06-2012, 04:35 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by kentactic View Post
What make model and year pickup tube should i try?
What's the block out of? Give us the alpha-numeric code off the passenger side block deck at the very front of the block. Whose pan are you using? What part number? We don't know at this point if the pan is wider with the same depth or deeper with the same width or what. If it's just wider with the same depth, you can use the OEM pieces. If it's deeper, then you'll have to use an extended pickup.
