pressing oil pickup tube - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-07-2012, 05:48 PM
Ok i got the pickup on. I didnt get it pressed all the way in, but id say its over halfway. I didnt want to continue hitting it as im pretty sure i would bust through the tube shortly. Is this thing in enough as it is in the picture (hard to really tell i know) that if ithe pan depth checks out i can tack weld it in place and call it good? Or if it checks out good should i just bang it all the way in and hope it dosent bust?
  #32 (permalink)
Old 12-10-2012, 05:14 PM
farmwalker's Avatar
What is the part number on that pick up tube? And whats your pan depth?? I have a 8 and 1/4 deep pan with the same pump. I got a simillar looking pick up and it would not fit. The pick up tube went too deep and was tuching my pan. When I called the store back, they said "that's the one the computer said was for it;" so they did a mock up on a block and HV pump they had there and it wouldn't fit there either. They ended up giving me a moroso pick up for cost. It was only 10 bucks more then. SO CHECK YOUR DEPTH BEFORE YOU GO WELDING ANYTHING. Other than that have fun!!
  #33 (permalink)
Old 12-10-2012, 06:05 PM
Im not sure it even has a part number on it. Its not infront of me to check but i dont recall seeing one. I will deffinatly test fit before i weld it though.
  #34 (permalink)
Old 12-11-2012, 11:51 AM
1971BB427's Avatar
They rarely seat all the way in, so if the mounting tab lines up with the bolt it's good. Since the pickup is on the suction side, not pressure side, it doesn't have leak issues unless it's loose in the pump.
It's in now, but in the future if you have issues pressing a pickup tube into a pump try lightly sanding the end of the tube on a sander. I bevel the end on my belt sander before trying to press them in, and it really does well in making them go in easier.
  #35 (permalink)
Old 12-11-2012, 12:42 PM
Ya i beveled the edge with a file to get it to go. The bolts didnt line up all that well. I kind of fudged it.
  #36 (permalink)
Old 12-11-2012, 01:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Might be too late to help you, but:
Oil pump pick up installation tool
oil pickup tube whojohnjones Engine 9 08-05-2011 07:53 PM
Oil Pump Pickup Tube 1975yellowC3 Engine 4 01-04-2011 07:29 PM
aftermarket pickup tube installation dirtinla Engine 1 11-29-2008 05:08 PM
Checking the pickup tube? HemmiGremmie Engine 5 03-10-2006 08:39 AM
pickup tube wont fit in pump Johnn Engine 11 04-25-2005 11:12 PM
