Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Presssure readings in 1993 4L60 trans
Old 09-06-2010, 07:15 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by SSedan64
Casey the Line Bias Valve is in Valvebody not the Pump, probably just looking at wrong section of Manual.
Look here at bottom of page 11 for Line Bias location>> http://www.sonnax.com/instructions/SC-4L60-IN.pdf
I had thought since he was working on the valve body and pump areas he would see the line bias valve in the valve body as he reads labels.
my bad
