Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Presssure readings in 1993 4L60 trans
Old 09-06-2010, 04:04 PM
kwacasey kwacasey is offline
Had a friend sit in the car this afternoon and hold the car in gear with the breaks so i could get some pull measurements after doing this i found that my max pull at idle in D/OD was around the 175 mark but it fluctuated quickly back and forth +/- 15 psi. does this sound normal?
