-   -   Presssure readings in 1993 4L60 trans (http://www.hotrodders.com/forum/presssure-readings-1993-4l60-trans-183905.html)
kwacasey 09-05-2010 12:10 PM
Just rebuilt my first 700r4 in a 1993 Z28 that I picked up real cheap (due to trans issues). With everything back together the trans seems to shift and work, but lacks holding power. (I am very proud of this)
After doing some pressure testing and searching this and other sites, i found that my base line pressure seems OK but WOT pressures seems low. So, I changed the TV Boost valve and Reverse Boost valves to upgraded over-sized/O-ring units. Below you can see my before and after pressures:
Before boost valves:
Gear base/max
R 75/190
N 75/125
OD 75/125
D 75/125
2 75/175
1 75/175
After boost valves:
Gear base/1500rpm
R 75/240
N 75/150
OD 75/150
D 75/150
2 75/175
1 75/175
*Max was determined by a hand pulling the cable at idle*
Even when the TV cable was adjusted properly i could not get over 10-15 psi change at 1500rpm in any gear. This seems much too low to me.
I have made a few assumptions such as because I can achieve a line pressure reading of 240psi, the pump is able to produce pressure so it most likely is not the problem.
Also, now that i have changed the Boost valves out, they are eliminated from the troubleshooting process, leaving only the TV valve assembly or internal leak.
I suspect SSS, but do not know enough to be confident here. Could it be the TV valve itself? How can i check this in the VB, or do i just have to blindly replace the valve and spring and monitor results?
Any help here would be appreciated, i am really trying to understand my problem and how to go about troubleshooting issues with this trans.
Thanks
KEN
Crosley 09-05-2010 05:21 PM
Unless the line bias valve spring is replaced with a stiffer spring... the pressure of main line will be low or slow to respond (increase) even with large boost valves as you have installed.
You see higher pressures in R , 1 and 2 gears because GM engineered the trans to boost pressure 'more' in those gears.
Did you install a .500 main boost valve? With a .282 or .296 low - rev boost valve ?
kwacasey 09-05-2010 07:26 PM
I did upgrade to the 0.500" TV boost and 0.283" Reverse boost, both with O-rings and both sonnax parts from my local transmission parts house.
I am not sure which spring you are referring to because i only know them by the names given in the manual. I assume you are talking about the Throttle valve spring in the valve body, but there is also a spring between the reverse boost valve and pressure regulator valve in the pump. Please let me know which one you are suspecting.
Should both of these springs be replaced?
thanks in advance for your patience with a newbie
Crosley 09-05-2010 08:02 PM
The line bias valve is known as that in all the manuals I have seen.
What manual are you using?
The line bias valve blows off pressure. With a larger boost valve it blows off more pressure, the larger boost valve over comes some of the pressure loss via pump RPM
SSedan64 09-06-2010 04:05 AM
Casey the Line Bias Valve is in Valvebody not the Pump, probably just looking at wrong section of Manual.
Look here at bottom of page 11 for Line Bias location>> http://www.sonnax.com/instructions/SC-4L60-IN.pdf
Crosley 09-06-2010 07:15 AM
I had thought since he was working on the valve body and pump areas he would see the line bias valve in the valve body as he reads labels.
my bad
kwacasey 09-06-2010 10:09 AM
OK, found the line bias valve. I guess i did not realize its function. I have rebuilt this trans using a combination of astg manual excerpts, online info that i found for the 4L60 and 4L60E, and the rebuild DVD.
From what i am understanding i need a stiffer spring that will not allow the valve to blow off the pressure on the forward gears, so it will allow for higher line rise.
I am seeing that some people are blocking off this valve? this sounds like a mod, should i consider this? If i were to replace the spring which one (color) should i use?
aside from this does my 10-15 psi boost at 1500rpm sound right? Just want to make sure that my TV setup is good.
Thanks again for your help on this.
kwacasey 09-06-2010 04:04 PM
Had a friend sit in the car this afternoon and hold the car in gear with the breaks so i could get some pull measurements after doing this i found that my max pull at idle in D/OD was around the 175 mark but it fluctuated quickly back and forth +/- 15 psi. does this sound normal?
