Unless the line bias valve spring is replaced with a stiffer spring... the pressure of main line will be low or slow to respond (increase) even with large boost valves as you have installed.
You see higher pressures in R , 1 and 2 gears because GM engineered the trans to boost pressure 'more' in those gears. Did you install a .500 main boost valve? With a .282 or .296 low - rev boost valve ?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I did upgrade to the 0.500" TV boost and 0.283" Reverse boost, both with O-rings and both sonnax parts from my local transmission parts house.
I am not sure which spring you are referring to because i only know them by the names given in the manual. I assume you are talking about the Throttle valve spring in the valve body, but there is also a spring between the reverse boost valve and pressure regulator valve in the pump. Please let me know which one you are suspecting. Should both of these springs be replaced? thanks in advance for your patience with a newbie |
The line bias valve is known as that in all the manuals I have seen.
What manual are you using? The line bias valve blows off pressure. With a larger boost valve it blows off more pressure, the larger boost valve over comes some of the pressure loss via pump RPM
Casey the Line Bias Valve is in Valvebody not the Pump, probably just looking at wrong section of Manual.
Look here at bottom of page 11 for Line Bias location>> http://www.sonnax.com/instructions/SC-4L60-IN.pdf |
I had thought since he was working on the valve body and pump areas he would see the line bias valve in the valve body as he reads labels. my bad
OK, found the line bias valve. I guess i did not realize its function. I have rebuilt this trans using a combination of astg manual excerpts, online info that i found for the 4L60 and 4L60E, and the rebuild DVD.
From what i am understanding i need a stiffer spring that will not allow the valve to blow off the pressure on the forward gears, so it will allow for higher line rise. I am seeing that some people are blocking off this valve? this sounds like a mod, should i consider this? If i were to replace the spring which one (color) should i use? aside from this does my 10-15 psi boost at 1500rpm sound right? Just want to make sure that my TV setup is good. Thanks again for your help on this. |
Had a friend sit in the car this afternoon and hold the car in gear with the breaks so i could get some pull measurements after doing this i found that my max pull at idle in D/OD was around the 175 mark but it fluctuated quickly back and forth +/- 15 psi. does this sound normal?
| dipstick problems with 350 trans | merowe | Transmission - Rearend | 5 | 08-15-2006 03:42 PM |
| First time trans rebuilder...need tips! | 4 Jaw Chuck | Transmission - Rearend | 14 | 06-23-2004 02:29 PM |
| 700r4 or 4l60 and how can I tell the differents | TooEz | Transmission - Rearend | 11 | 02-02-2004 03:58 AM |
| Turbo 350 to a '94 700R4 or 4L60 | classic_chevy_guy | Transmission - Rearend | 9 | 01-27-2004 09:32 PM |
| Fine Metal in Trans (NEW) | bigjoedo | Transmission - Rearend | 1 | 08-09-2003 01:23 PM |
