Pressure check 700r4 transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2008, 12:05 PM
I want to check the pressure on a 700r4. When this is done, is it on stands, or using brakes and shifting thru? How do I go about doing this the right way?
Thanks
Old 02-21-2008, 12:26 PM
66chevystepside's Avatar
Here is some info I found, I'm sure there is more on the web if you search for 700r4 tv installation, calibration, etc. Hope this helps
http://www.tvmadeez.com/pressure_test/index.php
Old 02-21-2008, 03:15 PM
Thanks a lot, chevystepside, that was exactly what I wanted to know. I went to that site when I set up the tv cable, but did not look around enought I guess. Thanks a lot.
Old 02-21-2008, 06:25 PM
No problem... glad to help out.
transmission column linkage- 700r4 to a t-350 frank88chevy Transmission - Rearend 1 01-02-2008 11:27 AM
700r4 low pressure hudsonman Transmission - Rearend 3 11-06-2006 09:49 AM
700R4 Low Pressure Problem 31rdster Transmission - Rearend 8 11-26-2004 08:43 AM
700R4 transmission install Decho Transmission - Rearend 3 08-13-2004 11:54 AM
transmission 700r4 output shaft slop catscan4free Transmission - Rearend 3 01-25-2004 08:11 AM
