Pressure Gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2011, 07:50 AM
Pressure Gauge
I am currently rebuilding my 1983 chevy c10 and on the electric oil pressure gauge connection at the sender I am only getting 7 VDC to ground What can I check I think I am supposed to be getting 12 VDC at this connector
Old 10-28-2011, 08:36 AM
It may be normal. The pressure gauge in the dash may have an internal voltage regulator built in, so voltage variations in the electrical system of the car do not affect the oil pressure gauge readings.
Does the gauge and sender combo work?
Old 10-29-2011, 04:14 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
What is the problem if any?
The oil pressure sender varies the resistance to ground. As the oil pressure increases the resistance decreases.
When the engine is stopped the OP is 0# and the resistance is infinity. As the OP increases the resistance drops but will not reach 0 ohms which would give you 12 volts at the sender.
OHMS law.
vicrod
Oil pressure gauge chevy305ranger General Rodding Tech 12 05-09-2009 02:53 PM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
oil pressure gauge Roys78chev Engine 2 07-29-2005 10:14 PM
Oil Pressure gauge Steve B Engine 4 10-15-2003 07:15 AM
oil pressure gauge 69 chevelle SS Engine 2 06-22-2003 08:18 AM
