pressure at the gun inlet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2010, 10:51 AM
gto_ron's Avatar
I bought myself a Father's day present, an IWATA LS400 W/1.3 tip and I'm still getting use to it. The manual recommends 20psi max pressure at the gun inlet but I'm use to using 35-45psi with my other guns. I shot a fender last week with the new gun and cc and it came out sh***y. There were dry spots and orange peel everywhere and it didn't seem like the paint was well atomized. I set the gun up by using the masking paper on the wall and the 1-second trigger squeeze, I had a good fan, good coverage and no runs. I had a regulator on the gun and kept the pressure at 20psi. What psi do you forum members with the LS400 use at the gun? Any other suggestions?
regards
Ron
Old 06-29-2010, 03:12 PM
Countilaw's Avatar
Cox Custom Cars
It should be 20 psi at the tip. With clears you don't worry about what the book says. You set your gun to spray the way you want it to spray. Spray a piece of paper on the wall and hold the trigger for one full second. Open the fan to 8 inches, if it runs, reduce your fluid control, if it's splotchy, increase pressure.
Old 06-29-2010, 09:07 PM
302 Z28's Avatar
Set the pressure at whatever setting gives you acceptable results.
Vince
Old 07-04-2010, 12:49 PM
gto_ron's Avatar
thanks, you all were right.
I bumped the pressure at the gun up to 30 psi and re-tuned the settings with the masking paper on the wall method. I sanded off most of the previous cc. This time the IWATA layed the cc on as smooth as glass. I'm not sure why the manufacturer's recommended psi at the gun(19psi) didn't work as well as the higher pressure I ended up using. There definitely was a lot more overspray at the higher pressure.
regards
Ron
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 08:18 PM
Newbie with an HVLP paultsmith Body - Exterior 27 07-13-2009 08:16 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
buying new gun, reduced pressure style rsss396 Body - Exterior 4 03-23-2005 10:53 PM
Eastwood's Rubberized HUMAN coating gun. WATCH OUT Pencilneck314 Body - Exterior 9 06-20-2004 10:56 PM
