pressure plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 06:12 AM
37 ford
pressure plate
Can anyone tell me if a chevy pressure plate is the same bolt patern as a pontiac? I'm putting a 4 speed behind a 455
Old 03-07-2012, 07:12 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
the 455 pontiac clutch assy's are the same as a big block chevy....if you're not sure what you got,put it up to the flywheel.
Old 03-07-2012, 02:39 PM
37 ford
flywheel / rearend unit
I asked earlier today about a pressure plate , I should have asked if the flywheel bolt pattern is the same on a chevy and a pontiac also I am trying to ID a couple of chevy rear ends, I have a posi unit in a camaro housing that I am trying to find out if it will fit in one of the two chevelle housings i have. I found a web site that says there are #s 410408 as a series 3 or 410409 as a series 2... I can 't find these numbers anywhere on housing or the unit it self , one site said to measure the distance between the very bottom hole and the next hole to the right or left. 3 1/4 as a 7.5-- 3 3/4 as a 8.5 All three of the housings I have measure 3 1/4 I think. I am triying to put a posi in a 65 GTO I'm using a chevelle rearend because chevy parts are easier to find. Thanks for any help
clutch stuck to pressure plate amature Transmission - Rearend 1 08-28-2011 07:21 PM
direct clutch pressure plate runn141 Transmission - Rearend 3 12-02-2007 05:19 PM
Which clutch/pressure plate to use? mrl Transmission - Rearend 6 01-12-2007 02:00 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 11:51 AM
new clutch, used pressure plate? chevyelc81 Transmission - Rearend 11 10-16-2002 04:14 PM
