Pressure pot troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2013, 07:31 PM
I have decided to upgrade to a pressure pot system for spraying glue. I am having trouble with the glue drying in the fluid hose, making it useless. Not sure what I am doing wrong, I closed the petcock when finished and closed the fan on the gun. The hoses are cheapo's , but I have a new quality set on the way. I also have a new CA technologies panther 100g gun on the way. I don't want to clog the new stuff up. I am spraying dap hhr top and trim, and never had trouble with it drying in the old siphon gun. Any help is appreciated, Jeremy
Old 06-11-2013, 08:25 PM
Last journal entry: Getting Started with Upholstery
I have the Binks setup. I keep pressure on the pot all the time and don't make any changes to anything between uses. It is always at the ready. I keep the pot over 1/2 full. Never had a problem with glue drying up.
Old 06-11-2013, 09:49 PM
The glue is drying in the fluid hose only, the pot is fine. I have killed 2 cheap fluid hoses. It is driving me crazy !!! It is dry in the hose over night. I haven't been keeping air pressure on the tank, but I do close it.
Old 06-11-2013, 10:13 PM
I use the Binks fluid hose. Perfect Fit has very good prices on it. If the glue is drying in the hose that means the solvents are somehow evaporating. I suspect this could be an issue with the quality of equipment..
Old 06-12-2013, 02:49 AM
Thank you slodat, I am thinking the same thing, so I do have a quality fluid hose on the way, it's advertised for adhesives...and cost 65$. A reasonable price if I don't ruin it the first night!!!
Old 06-12-2013, 07:48 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Slodat is right, cheap equipment won't work when you're using a pressure pot. Hang the spray nozzle up high when you're done spraying and let gravity return the glue to the pot. It also helps to be using the equipment regularly. I just think it's way too clumsy to wrestle with those two hoses. I tried it and went back to a conventional spray gun.
Old 06-12-2013, 08:01 AM
Dan is right about the two hoses. My hoses are tied together, in a very neat fashion, so they function as one hose. About to put a TIG torch cover over them to make it even better. Spraying upside down and not having to refill often are quite nice. It also never falls over.
Old 06-12-2013, 09:33 AM
Wiki Edits: 22
Did you see the Binks attachment for the spray nozzle that allows you to get into tight places easily? It's basically just a plastic tube with a way to attach it to the spray nozzle. Looks interesting, and can't cost much. Look at page 6 in this pamphlet: http://www.binks.com/Portals/0/repos...sivesguide.pdf
Old 06-12-2013, 06:05 PM
My new hoses should be here by the end of the week, I will see what happens!!! Thanks again
Proper pressure setting for pressure pot supply? 777funk Body - Exterior 2 03-06-2012 12:20 PM
Brut Pressure Pot Blasters... 41chevyman Body - Exterior 3 04-22-2007 10:42 AM
pot belly RONALD T ALLEN Introduce Yourself 1 05-24-2006 10:54 AM
question about pressure pot sandblasters modas Body - Exterior 4 02-01-2006 05:13 PM
Pressure pot painting S10xGN Body - Exterior 1 01-31-2006 07:02 PM
