Pressure reducing on mustang II rack? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2006, 12:14 PM
Last journal entry: Body work
I need to start working out the plumbing on my rambler for the power steering and brakes. I'm using the stock pump on the 94 Lt1 motor in the car. Also, I plan on using a hydro-booster for the brakes, so I don't want to reduce the pump pressure. I was thinking of the addition of a pressure bypass valve of some kind in the supply line from the hydro-booster to the rack and a return line to tank. Has anyone used these valves, and are they even necessary. Thanks.
Old 01-26-2006, 02:34 PM
BOBCRMAN@aol.com's Avatar
Several of the Street Rod suppliers sell a r/p valve to use GM pump on Ford rack. In the old days we used to clip the spring. You should still have ample power for a hydro/vac brake system.
Old 01-26-2006, 05:38 PM
Wiki Edits: 49
Check with Borgeson for a kit to modify the GM pump. They're cheap and very easy to install.
Mustang II power rack rebuild americanLT1 Suspension - Brakes - Steering 5 04-08-2005 07:47 PM
66 mustang rack and pinion jellybean Suspension - Brakes - Steering 2 06-24-2004 10:24 PM
Mustang II bump steer, drifting Chev283 Suspension - Brakes - Steering 2 06-19-2004 09:15 PM
Mustnag II rack and pinion Echofive Suspension - Brakes - Steering 3 05-26-2004 07:26 PM
Flaming River Mustang II Power Rack? acr Suspension - Brakes - Steering 1 02-19-2004 06:57 AM
