pressure regulator valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2009, 08:53 AM
Whats the lowdown on grinding the flats on the regulator valve for the 700r4? Both manuals that I had said to do it, but now I've found some discussion that seems to indicate that it is a bad thing. What is the purpose of it? Does it supposedly increase pressure or just volume. I always thought the pressure was controled by the spring.
I need some help with my 350 Chevy engine... piniongear Engine 92 07-17-2008 12:57 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
oil pressure switch Blob Engine 7 12-02-2005 12:34 PM
Crankcase pressure effect on oil pressure? cboy Engine 8 06-12-2005 08:04 AM
fuel pressure accessory CORNFUSION!!! killerformula Engine 10 07-06-2004 08:02 PM
