Pressure regulator valve stuck in bore - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2010, 03:05 PM
I was installing shift kit in my 700 r4 , went to put pressure regulator valve back in bore, started to go in nice then it was sticky... i gave it a few taps with a screw driver and now it seems to be stuck worse... researching again said tap it more to help un stick... but now it looks hopless... no movement at all... anyone have any advice on how to get this thing out?.. I know the pieces went back in the correct order but I'd feel much better taking it all out...HELP
Old 10-18-2010, 06:18 PM
001mustang's Avatar
Typical tranny valves should move freely enough to fall out under it's own weight or w/ a pocket magnet.
Sticky valves are a common cause of tranny problems.
If they are tight you must find and correct problem.
Did you drop the valve?
Perhaps some grit hitched a ride in w/ the valve?
Does the valve exposed end have a open ID?
No where to grab it w/ a bent pick?
Can you pressurize other side to pop it out?
May be able to shrink it w/ liquid O2.
Got a pic?
Old 10-18-2010, 08:54 PM
i got it out finally... but the Tv boost valve sleeve is now damaged...I will order new parts tomorrow(Tv boost valve sleeve, reverse boost valve sleeve etc..)
Old 10-18-2010, 09:11 PM
SSedan64's Avatar
May try blowing air in the suction hole where filter neck goes.
Needle nose pliers may reach the end of the Pr. valve if Spring & TV,L/R boost valves are removed..
Pic of it here @bottom of Pg. http://www.sonnax.com/instructions/77917-471-IN.pdf
You can have the Bore cut & reamed for a larger valve also.
http://www.sonnax.com/part_summary.php?id=3364&pl=3
I was posting while you were working. The 2nd link may still be of benefit tho'.
Old 10-18-2010, 09:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
so........... are we talking the actual PR valve was stuck or the boost valves were stuck?
Sounds like the boost valves is what we are talking about?
Old 10-19-2010, 07:13 AM
sorry guys... I was so frustrated with what had happened... it was the boost valve sleeve that was stuck... I got it out.. must have been some gunk on the bore hole... My next question is ...
I have 20004r boost valve sleeve, boost valve reverse boost valve sleeve and reverse boost valve left over from a 200 4r I worked on... are they the same... just by eye balling them they look the same?... could I just use them as replacement parts?...
Old 10-19-2010, 07:39 AM
everywhere I looks lists them as the same part number... so i am going to use the 200 r4 parts I have... hope you guys don't have bad new for me later...
Old 10-19-2010, 07:59 AM
SSedan64's Avatar
Yes, 2004R & 700R4 use the same style valves. The diameter of the Boost valves may be different as they come in several sizes.
No oil pressure v8hed Engine 13 07-20-2010 03:42 PM
TPI fuel pressure slowpoke Engine 21 06-07-2010 07:13 AM
'89 C2500 TBI 5.7L oiling problem Trainwreck Engine 11 05-20-2010 06:13 PM
fuel pressure accessory CORNFUSION!!! killerformula Engine 10 07-06-2004 08:02 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
