-   -   pressure switches or ...? (http://www.hotrodders.com/forum/pressure-switches-118719.html)
hugger 06-23-2007 05:05 PM
What I believe to be a 1992 700R4 (not 100% sure of the year). I have two switches on the valve body one threaded into valve body the other bolted on top, I can identify the 4th gear pressure switch and I will use it for my lock-up that's clear but what is the switch bolted onto the exterior of the valve body ? It is wired across the black and white wire, I'm guessing that it may be a temperature switch? :confused:
I'm sure that someone here knows what the heck it is? (Crosley no doubt :thumbup: )
Thanx in advance
Jmark 06-23-2007 05:11 PM
Yes, it is a temp switch. According to Crosley ( I hope!LOL) it can be bypassed and removed without issue.
hugger 06-23-2007 05:37 PM
switches
Actually if it is a temperature switch wouldn't it be best to use it? My understanding is that the factory arrangement waits until the motor/trans is about 170 Deg before allowing lock-up. Any comment ?
Crosley 06-23-2007 09:52 PM
its a high temp switch..... engages lock up if the temps are tooo high to kool the trans off
