pressure switches or ...?
What I believe to be a 1992 700R4 (not 100% sure of the year). I have two switches on the valve body one threaded into valve body the other bolted on top, I can identify the 4th gear pressure switch and I will use it for my lock-up that's clear but what is the switch bolted onto the exterior of the valve body ? It is wired across the black and white wire, I'm guessing that it may be a temperature switch?
I'm sure that someone here knows what the heck it is? (Crosley no doubt Thanx in advance |
switches
Actually if it is a temperature switch wouldn't it be best to use it? My understanding is that the factory arrangement waits until the motor/trans is about 170 Deg before allowing lock-up. Any comment ?
its a high temp switch..... engages lock up if the temps are tooo high to kool the trans off
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| 2000 Buick tranny shifting weird? | frankenvette | Engine | 6 | 06-13-2006 07:28 PM |
| 4L80E diesel computer | 5foot2 | Transmission - Rearend | 2 | 04-09-2005 12:48 PM |
| Oil pressure loss SB Chevy | Finmike | Engine | 30 | 06-12-2004 10:27 AM |
| Fuel Pressure | DoubleVision | Engine | 18 | 05-31-2003 05:49 AM |
