Pressure Washer - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 06:06 AM
Pressure Washer
Hey guys,
I am interested in getting a pressure washer and would like some recommendations. I only have about $200.00, what do you suggest? What PSI do I look for, etc. Any recommendations you have are appreciated.
Thanks
Dave
Old 02-22-2007, 06:34 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Actually, I just bought one from sears for under $200 on sale. Gas powered 4 HP. no wheels, but it's real light so it's actually easy to carry and doesn't take up much space in the shed at all. 3 nozzles plus a soap nozzle.
just search for 07175201000 at sears.com
Old 02-22-2007, 11:23 AM
I bought one at Lowes a couple of years ago for under 200.00, has 2400 psi, as I recall.
Old 02-22-2007, 08:43 PM
tjn tjn is offline
tjn/56nomad
pressure washers
Daveh, be warned that when the washer is not spewing water, it is not cooling! In other words if the engine is running but the "wand" is in the off position, there is no water flow. These pumps rely on water "movement" for cooling purposes, and the pump can quickly burn out.
Make sure that the pump can be serviced/waranteed locally, as that is the weakest link. Purchase the unit with the highest pressure that you can aff
ord, as that will shorten your work time as well as producing better results. Best of luck! TJN/56Nomad
Old 02-22-2007, 10:07 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
$200.00 is a prettly low-budget pressure washer.
My all-time favorite is the Water Wacker, mfg'd by FAE. They're referred to as the "Cadillac" of pressure washers, and I've sold quite a few of them at the NAPA store I used to work at.
It's a fairly common design in this part of the world.
These are serious units that are built to last, and to be serviced when things wear out.
They're a little more pricey, though ... about $1000.00 CDN
Old 02-23-2007, 08:45 AM
302 Z28's Avatar
Low end pressure washers are generally disposable. As mentioned they do not have by-pass valves that allow water to circulate when the wand is off. Also the pumps on these cheapo washers are not something you can service if need be.
Vince
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
2000 Buick tranny shifting weird? frankenvette Engine 6 06-13-2006 07:28 PM
Need help with hotwater pressure washer shockers69 Garage - Tools 1 06-09-2005 02:36 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Fuel Pressure DoubleVision Engine 18 05-31-2003 05:49 AM
