Pressure washing engine with internals still in. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2008, 10:09 PM
Rubberman2003's Avatar
I was wondering if there is a good way to pressure wash an engine while the pistons and all the guts are still inside it. I want to get it clean to paint it before putting back in my truck. Its a dodge 318. The intake is off getting its own paint job. Also the exhaust manifolds are off. Could i just stuff the holes with shop rags and spray carefully near them? Thanks
Old 11-10-2008, 08:01 AM
how dirty is it ?
i'd brake clean and duck tape it up good , being your tape will be where the gaskets go ,if you pressure wash it .
i usually just brake clean , let dry , when dry , wire brush will remove the grease that the brake clean dried out .
spray more brake clean after and wipe up good .
wire brush some more and then paint it .
lacquer paint thinner works good also .no mineral spirits ,or carb cleaner as it has what looks like trans fluid in it now.
what you planing on using for paint ?
i found that rust olumn spray paint will work better than that thin as water heat paint you buy , and it only takes one can to paint all , that heat paint takes two cans, and usually flakes off later .
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 08:26 PM
