Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Presure, Where Did It Go?
Old 05-25-2002, 07:25 PM
Pontiacman Pontiacman is offline
Try again your noticeing pressure decreasing sounds like you have a pressure gauge or pressure
regulator in between pump and carb, if so just for fun remove it and go straight to carb( could have flow direction backwards,mechanical fuel pump I would think either works or not.Oh, just thought of something, your fuel line isn't
up to high( on fender or somewhere else high up)
mechanical fuel pump won't work correctly if line is up high ,loses suction, keep up posts
