Price for big block chevy head - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2005, 05:39 PM
Ratoflic's Avatar
Big cubic inches small Chevy!
Hi everybody
I project to sold my head, I would like to know the value of those head!
There is my setup
Oval port iron GM head 353049
Stage 3 porting and polishing
Check for crack and magnafluxed
2.19 and 1.88 Manley severy duty valves (3/8)
double valve spring with 10 degre chrome moly retainer (matching with 305H hydraulic comp cam)
115 CC combustion chamber (Shave to 40 thousant)
brand new bronze guide
Thanks to help me (I project to put aluminum head on my Nova SS 74, 468 BBC)
Chevy man forever!
Old 07-25-2005, 06:45 AM
One head or two ??
Rodders can get new aluminum heads for decent prices now.....so you might be disappointed with what your heads would bring. With all the new stuff, I know you must have a good bit of $$$ in them.
It is cheaper now to buy good aluminum heads than rebuild old heads and then try to bring them up to the new heads performance potential.
No dollar value from me.........
Old 07-25-2005, 08:34 AM
Ratoflic's Avatar
Heads value
this is for both head, in fact, I was putting around 1500 canadian bucks in it, I want to know the value, because I really want to put aluminum one, for temperature, and run higher comp ratio with pump gaz (and performance too)
Originally Posted by Deuce
One head or two ??
Chevy man forever!
Old 07-25-2005, 08:46 AM
New Member
Last journal entry: 88 up chevy truck bench seat
how much are you looking to get for them rat? iam in nova scotia?
george
Old 07-25-2005, 08:59 AM
Ratoflic's Avatar
Price???
I really dont know, it's was putting more than 2000$ with the roller rockers and all the stuff......I would like to have an idea for what is the price on the market for a set of head ported last years...on thing is sure, my car is a beast with this set of head (468 CI and 9.6 CR), I want to change my goal....I want to run high ten with 91 pump gaz normally aspirated on street car!....I Think I'm not really far from this goal with those head, but I want to run little bit compression ratio with the same gaz.
I think they value at least 1000$....it's why I want to have an idea on this site...
Chevy man forever!
Old 07-25-2005, 10:43 AM
New Member
that a $1000 with rockers?reason being a set of 781 (the 049 replacements) are for sale with big valves and teflon seals, good springs and decent port job(not sure what stage you would call it but bowls blended and pockets as well)$400 for the heads here in nova scotia. if rockers go with i would offer up $800. if you have pics send to: kimgeorge@eastlink.ca thanks george
george
Old 07-25-2005, 10:52 AM
Last journal entry: pro systems carb
Around a grand sounds good. There are a few Canuck examples on RPM classified . com some with intakes and so on. Dont take less than a grand , dont include roller rocker's, that would be 1400.00 or so Can.
Old 07-25-2005, 12:27 PM
Ratoflic's Avatar
Head!!
I think your right, I forgot to tell they have 3 angle valve job!
The rocker are Crane full roller with 1.7 Right now, I have and Idea, I will probably sell those head to have a set in aluminum. Thanks allot!
Chevy man forever!
Old 07-25-2005, 12:34 PM
New Member
at $1400 i would probably save up the extra $600 for edelbrock performer rpm. just going by the heads buddy showed me on the weekend. $400 for 781"s with mild port job and good springs and 2.19 and 1.88 valves. no harm in making an offer?
george
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
400 small block compression and head gasket question 19nova72 Engine 2 07-07-2005 09:49 PM
Chevy aluminum small block swap rick_blankenship Engine 3 11-17-2003 06:09 PM
Big Block Chevy Stroker Kit invincible Engine 3 11-11-2003 06:04 PM
Need Info On 72 Small Block Chevy impala59 Engine 5 10-01-2003 05:11 PM
