price to straighten rear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2007, 11:48 AM
1948 thames's Avatar
Is 150.00 a decent price to straighten a narrowed 9in ford housing? Seems high to me but I could be wrong. Thanks.
Old 04-28-2007, 09:33 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the price would vary with the needed work.....
heating and pulling or IF the housing is bad enough one bearing end may need to be cut off and rewelded....
just my random thoughts
Old 04-28-2007, 02:06 PM
powerrodsmike's Avatar
Wiki Edits: 161
What Crosley said....plus, the shop rates are at least 75.00 an hour around here for any kind of work like that.
Now usually a shop owner and customer guy will spend 20 minutes minumum talking about doing the job, (if it's a hot rodder, probably more like 45 minutes to an hour), then the job will probably take at least an hour and a half, probably more like 2 or more if it is the rear end that you wrote about in this thread here,..
Is this rear bent?
That rear end is bent pretty bad.
Then the paperwork will need to be done and administrative costs figured in and you have spent at least 3 hours talking about and doing a job that you will make 150.00 for. 50.00 an hour is no kind of decent shop rate in any part of California that I know of. Hopefully the guy will do it right the first time , so you dont have to find someone who will do the job a second time.
I charged 300.00 for the last one that I did, and I'm charging that for the next one. That will be my BAR required estimate, if it takes me less time I'll give the guy back some money.
(BTW, I don't want to straighten your rear end housing.)
I'd say go for it before that guy prices himself out of business.
Just my opinion .
Mikey
BE different....ACT normal.
Old 04-28-2007, 08:35 PM
300.00 just to straighten a housing? Well I guess it depends on what side of the counter your on whether or not who thinks that is a fair price.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 07:09 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
