prime with old gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2013, 08:19 PM
prime with old gun
Hi
I want to use a Binks spray gun model 18 Please don't tell me to hang it up or not to use this gun. thanks
I am having trouble setting gun . not sure what each knob is to do
primer came out dry . so would like to learn how to adjust gun. I am using Dupli color primer, with Lacquer Thinner, the can say to mix 1 to 1. The can say to set pressure 30 to 40 I tried 40 . It came out real dry , than set pressure at about 35lbs, than I played with gun adjustment, a little better but still not the way I think it should be. I would like it wetter so I can put more coats on. I feel I need to learn to adjust gun now.
Thank you abrenn
Old 07-16-2013, 07:13 AM
WOW 76 people read my post for help on how to adj the gun and no one knows how to do it, please some one help I have a lot of bear metal I want to get primed. thanks to some one
Old 07-16-2013, 08:50 AM
try this?
Old 07-16-2013, 09:28 AM
Last journal entry: Paint
How do you know it's the gun adjustment and not something else? How clean is the gun and what has gone through it before? How do you know it's not the primer you are using? Lacquer hmm.
Old 07-16-2013, 10:03 AM
Originally Posted by abrenn View Post
Hi
Thank you abrenn
The Binks 18 is the godfather of modern spray guns and is often copied by other manufacturers so there's a lot of similar guns out there. However compared to modern HVLP guns, the 18 looses a lot of paint to overspray.
This link should help with setting it up, basically you need more paint for the air your using, or less air but the paint may need to be thinned more for that, this is all quite a dance to work out the pattern and feed. <<< Basic Setup & Using the Controls - Spray Gun Basics - Mini Truckin' Magazine >>>
The top control is the the pattern shape, the second is fluid flow. It's a good idea to add a regulator and air supply fine adjustment valve to the air inlet.
The Binks 18 and it's many clones take a whomper/stomper compressor that can deliver a lot of CFM at fairly high pressure, the average 5 horse, single stage, 20 gallon tank home compressor isn't up to this task.
Bogie
Old 07-18-2013, 12:26 PM
I just want to thank u guys I went to you tube and watch some clips on cleaning gun. I took gun all a part , I never went that far be for, it was not bad no holes blocked, I always run thinner to clean when done. learn a lot . last night I adj gun and tried water on card board, that dryed to fast to see how pattern was. to day I mix up primer and tried that on card board that was so so . than tried on some tin. I am doing much better now. it is a little rough kind of like orange peal. it is hot here in N. W. Pa. I tried it in my basement it was about 70 with 63 humidity . It was some wet , I can probably live this. I would like to get it weter if I can . I had about 28 lbs with my binks 18 and got my fan to about 5 to 6 in.
I want to go down to night when it cools off and play some more .
should I try more pressure or just play with gun adj?? thanks again abrenn
Old 07-18-2013, 01:50 PM
Take careful notes of all the gun adjustments, environmental factors, viscosity of the paint, type of paint, reducers, and thinners, and anything else you can think of, and then note the results.
In my opinion, the biggest factor in how a paint lays down is how the gun is used. If you have the fluid control on the gun open a lot, for example, you can move the gun fast, and get a wet spray pattern. Conversely, with the fluid control closed down, you need to move the gun slowly.
I have seen posts on hotrodders.com asking about how to adjust a gun, when the problem was runs in one part of the panel, and heavy orange peel in another part of the panel. That is not an gun adjustment problem. That is caused by inconsistent speed of movement, and overlap.
has anyone tried this spray gun? im looking for a decent primer gun ((sr)) kelly Body - Exterior 3 10-05-2013 01:52 PM
poly prime gun help ERV JR Body - Exterior 7 01-08-2013 05:56 AM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
to prime or not? roykuz Body - Exterior 3 08-06-2007 03:40 PM
To prime or not to prime Chevy Thunder2 Body - Exterior 9 02-12-2004 11:39 AM
