primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2002, 10:51 AM
New Member
Post primer
I'm just assembling my street rod and i want to drive it a couple of months before laying down the paint what primer should i use if its going to be out in the weather epoxy, sealer?
Old 12-11-2002, 07:24 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Use a good sealer, not just primer. Primer is pporus and will absorb or let in moisture and you will eventually have rust forming.
HK
Old 12-12-2002, 06:04 PM
Location: 4839 university ave ne. columbia hgts mn. 55421
Post
do not use epoxy it will not hold up to sunlight.if it was me i would buy inexpensive single stage paint and add flattening agent to it. check with someone who sells ppg paint they have a fleet line of paint called omni its very inexpensive. you can buy it in single stage. buy the quart. you can also buy inexpensive sealer from omni. if you are doing it in your garage make sure buy the fastest drying reducers and hardners. collins motors
Old 12-16-2002, 03:54 PM
Post
I would use an epoxy promer and possibly a urethane primer over that. The epoxy primer is a good sealer for the base metal and it not a sandable primer. The urethane primer will be sandable but it tends to pick up stuff like bugs and oil from the road. You should also use a primer from the same manufacterer as the paint you plan on using. Paint manufacters do not warranty the paint job unless you use all their products, plus some paints will not work over other primers.
