primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2005, 06:38 PM
bct bct is offline
primer
The rear quarter panel on my 55 chevy needs a little body filler to cover up a few shallow dents and ripples. The previous owner sprayed the area with the cheap spray can gray primer. Do I have to sand off all of the primer or can I put the body filler over top of it. Thanks for the info
Old 11-15-2005, 07:56 PM
BarryK's Avatar
Must come off.
adtkart@aol.com
The best thing that you can do is remove that spray can primer. It will not hold up, and the filler will not stay on it for long. I would suggest primering it with an epoxy, and then apply any filler you need.
Aaron
Old 11-15-2005, 07:57 PM
Wiki Edits: 49
Very good advise so far.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 07:23 AM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 06:50 PM
2k Primer scraping off? Need help misteryu Body - Exterior 1 07-17-2004 05:55 AM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
