Primer Activator temp/speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2011, 07:43 AM
Hi, I'm ready to shoot high build primer in the garage and selected the activator based on the temps during the Fall here in MN. I selected the fast activator which says it's used for the temp range: 60-75 degrees. Unfortunately, I didn't do my homework and read the tech sheet first or read about it here on the forum. I have a feeling that I should have chosen the medium. I'm planning on a mostly sunny 65 degree day. Will this activator work for me or do I need to get a medium activator? Thanks, Grayle
Old 09-20-2011, 10:15 AM
it will ok. just keep it wet. primer is more forgiving than than paint or clear.
Old 09-20-2011, 12:05 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Make sure your metal is in the 60-65 degree range..the air temp may be fine but the metal may still may be cold..
Sam
Old 09-21-2011, 01:22 PM
Sounds good! I'll check the panel temp with a laser thermometer to make sure it's in the right range! Thanks!
high temp activator in lower temps for clear Rosewood Body - Exterior 5 05-25-2010 07:26 PM
Hello I have a primer/activator questions showtime808 Body - Exterior 3 01-31-2009 09:39 PM
spi 2k primer activator oldcarguy36 Body - Exterior 19 11-17-2006 11:45 AM
Basecoat Activator Need Help A.S.A.P!!! #1berettaman1991gtz Body - Exterior 1 08-01-2004 12:12 PM
