is primer affected by rain - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 08:37 PM
I recently primered my 1994 cadillac with nason high build urethane primer. i then block sanded the whole car and sprayed a layer of guide coat and blocked the whole thing again and some spots required glazing putty, so i apllied it then sanded the area. when i was done with the whole car i washed it throughly and there were some spots that i sanded down to the bare metal. unfortunately i left the car outside to dry before putting it in my garage for a second coat of primer and it began raining and wasnt home to get it out of the rain so it rained for a couple hours before i could wash it again to get it inside. so i was wondering if the spots that were sanded down to the bare metal should be sealed before i re-primer them or is the high build primer good enough as long as i wash the car throughly and there isnt any surface rust. im just concerned because this is my first time painting a car and don't want to waste any material or time. also will the acid from the rain affect adhesion of primer.
Old 06-28-2010, 10:07 PM
Countilaw's Avatar
Cox Custom Cars
apply a coat of epoxy sealer to the bare areas and then reprime. 2K primer sometimes doesn't like to stick to bare metal.
It's more of a "just to be safe" measure.
Frank Cox
Cox Custom Cars
Old 06-28-2010, 10:29 PM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
Just to be safe is always the way to go. All bare metal should be sealed.There are enough things that can go wrong with a paint job, the more things you can prevent the more success you will have.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 02:31 PM
PPG K36 primer w/ purple gun BIGSKY Body - Exterior 16 11-20-2006 01:12 PM
Primer Questions & observations x711 Body - Exterior 1 01-19-2006 10:23 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
