Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Primer before powder coating?
Old 02-05-2004, 08:41 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Use this stuff on the base metal like you would use bondo under a paint job for a perfect surface before powder coating. This will stand up to 1000F temperatures - the 400F that the coater use is the recommended curing temperature.
High temperature Lab Metal
